JIMNLIN
Oct 14, 2013Explorer III
Uneven wear patterns may not be the result of out of aligned axles. ST tires are notorious for full or partial tread belt separation. This can set up odd wear patterns around and across the tread.
Also worn suspension parts and loose wheel bearings can cause odd wear patterns in a tire on a trailer.
I've found big rig trailer repair shops can easily handle alignment of RV axles or suspension repair of any type. I've had many equipment trailers that were dragged side scrubbing over curbs/etc/etc with 3500 lb axle on up to 10k axles rebent with no issues. Shops like these will tell you what you what is needed.
