Hiking_Hunter
Oct 14, 2013Explorer
Huntingdog wrote:You're right - I can see that. I'm measuring hub to hub because it is the easiest way, although I can see now why it would be unreliable.
Pretty hard to get a reliable measurement as the equalizer can easily be cause it to be off by that amount. In fact that measurement changes constantly. And there is enough slop in the suspension to cause some more.
jmtandem wrote:I will do this as soon practical. But, won't I have the same error introduced by the slop in the suspension that Huntingdog mentioned? The trailer is a fifth wheel, so I'll measure from the center of the king pin. Of course I can't measure without pulling the string under the front. I guess that won't matter if it's the same path on both sides. Now, I just need to find a string that won't stretch...
Start with a measurement from the tongue to both axles at the same exact location on both sides near the end. Make sure that is within 1/8th inch. Then measure between axles with the trailer straight and level or measure from the tongue to the same place on both sides of the second axle and double check by measuring the difference between axles.
jmtandem wrote:Maybe not. He did, as close as we could get it, but with an axle that had moved and had to be moved back into place, the crack of the broken weld didn't match exactly. We couldn't get the hanger to sit up on the frame perfectly, but there was enough contact area for the weld. There was a gap in the some of the area of the break that was probably 1/8" wide, vertically; the rest was in contact. Front to back it was probably within 1/4". Of course, the other hanger on this suspension didn't move, and the other axle didn't move.
If your welder attached the spring hanger in the original location, you may not have an issue.
