Hiking_Hunter
Oct 14, 2013Explorer
JBarca wrote:Wow, that's good information. I haven't read it thoroughly, but just scanning it, I realize you put a lot of work into that report. One question - when you are measuring toe in, are you using a similar pattern in the tires as a reference point? And what are you comparing that to - the rear of the tire?
TT axle alignment & install - Detailed (long lot's of pics)
jmtandem wrote:My concern exactly.
I am a little concerned about the welder not putting the hanger exactly back where it was. That could be an issue.
I would go with the wet bolt kit as long as you are delving into the axle issues and if you have a Dexter axle also get the spring equalizers. They are rubber and work well. Some say they notice a better tow with the equalizers.I do have Dexter 6000# axles with the shackle type suspension. Good idea, I found this installation guide from someone who did the conversion.
Dexter EZ Flex Equalizer Upgrade
Thanks for the info, hopefully I won't have any problem, but I'll certainly check as soon as I can.
