gheicher
May 12, 2013Explorer
Using the 12 volt mode for the fridge uses a lot of battery power, anywhere from 10 to more than 20 amps depending on the size. Even if you have sufficient wiring from the tow vehicle, it puts a strain on the tow vehicle's electrical system (Older bulb type headlights use about 10 amps of power). Also an automatic disconnect should be installed to prevent draining the tow vehicle's battery when the engine isn't running.
If you must run the fridge when traveling, the LP mode is preferred. Some have difficulty keeping the heater lighted due to air turbulence and have added baffles to help out. Others always turn the fridge off when refueling due to the possibility of igniting fueling vapors.
The easiest and safest is to add some thermal mass (ice packs) inside the fridge and this will keep it cool for many hours. Keeping the fridge filled of cans of cold beer will have the same effect.
