JimVan
May 28, 2015Explorer
All terrain tires
I will be buying a new set of tires for my van, Costco has a good deal on a set of all terrain tires. My question is do they run any louder or rougher than normal LT tires ?
Usually the ride wont be any rougher than normal LT tires. As far as louder a lot depends on the tread pattern. One of the main things that makes one AT tire louder than another is the tread void (spacing and depth of tread). The greater the tread void the more likely to hum. I run Cooper Discover ATPs on my 2wd f250. They have a semi-aggressive tread pattern and decent amount of sipes in the tread. I run ATs because not all rv parks are paved, and they help in the loose gravel and occasional muddy conditions. Just base your decision on how you use your vehicle not just price.
