sasq40
Sep 13, 2019Explorer
Id have to use all the tool boxes for fuel to make up for my slip tank lol. Moving it forward also leaves alot of deck space behind the camper that I don't know how I'd utizile.
If the cog sticker on the camper is right on the axle, then shouldn't it be fine? Or is there something I'm missing?
I'd most likely change plumbing around rather then cut a hole in the deck.
Good thinking about something to keep it from going forward. The wood is mainly to get it high enough to clear the headache rack and line it up. So far it's done a good job of keeping it in place tho.
I did look into running the ties inside the boxes, but it uses up so much room that it wouldn't be worth the hassle
