qmrichardson
Aug 17, 2013Explorer
when I switched from my half ton truck to my diesel, the biggest thing I noticed was that the trailer no longer pushed the truck around. The bigger truck gives you confidence in that you have more control. As stated above, you will always feel something when big trucks are passing you. You are pulling a house down the road afterall... Kudos to you for spending the coin on the pro-ride. That's money well spent and will make your towing much safer than a cheap hitch. I've had several weight distribution and sway control setups and will never use another chain setup again.
