vern_kelly
Jul 24, 2022Explorer
My Onan 2500 LP has been flawless for 24 years. Only issue if battery is too low, will crank over but not fire, due to spark being too weak I suppose. Always turn propane on and run stove burner to get gas in system before starting if gas has been turned off a long while. Usually starts 2nd crank. Spark plug gap is set tighter than gas models. Taking spark plug out is tricky using 13/16 socket and a wrench on end (no room for ratchet).
Oil change only every 3 or 4 years because the propane models are so clean. Check oil with dip stick touching but not screwed in with camper level. Check air filter if run in dirty environment.
Enjoy!
Enjoy!
