normal_dave
Jun 24, 2017Explorer
I also like the Timber Ridge 23DBS.
Looking at your list, I would guess you are budget shopping like me. If you went by Cordelia RV, did you happen to walk through a Black Rock 23BKS?
If you don't really care about the outdoor kitchen, and you can supply your own LCD TV, then here's some magic that will save you about $ 6,500.00.
Pull up pictures of the Timber Ridge 23DBS, and the Black Rock 23BKS, side by side on your screen. Presto, identical trailer!
Timber Ridge is just dressed up a little more with features. The Black Rock also comes standard with the X4 off-road, package. Heavy duty shocks, Mor-Ryde suspension, greasable shackle bolts, bronze inserts, extra ground clearance.
I think the choice really depends on what type of camping and roads you will take, and how important the dress up items are. I actually like the rugged look of the Black Rock counter tops over the solid tops in the Timber Ridge.
Example:
Black Rock 23BKS
Hope that helps...
Example:
Black Rock 23BKS
Hope that helps...
