RV LP System Pressure is only 0.39 psi
Propane has a narrow combustion range...
less then 2% propane....no ignition
more then 10% propane...no ignition
Water heaters/Fridges air mixture for combustion is via venturi effect
Furnace is forced air for combustion
Water heaters/Fridges Can have ignition issues due to thinner air at altitudes
It can affect the fuel/air ratio...fuel rich condition
Suburban makes the statement about 'derating' water heater above 4500' and that change out of orifice is required........BUT do NOT specify WHICH orifice to use.
Derating by 4% per every 1000' Above sea level.
Norcold FAQs
Altitudes higher than 5500 feet above sea level may cause reduced cooling performance and may cause burner outages. Norcold recommends you operate the unit on AC when altitudes are higher than 5500 feet above sea level.
Most of the time...opening the access door/panel can help resolve the air issue
