adamis's avatar
adamis
Nomad II
Jul 02, 2017
Altitude Effects on Fridge?
I have been camping in northern California for the last two years with my 2001 Bigfoot camper. I have a Dometic fridge that I assume is from the same time frame (I bought the camper about two years ago).
On a previous Lance camper I noticed that the coils on the back of the fridge would get very cold to the touch. On my current camper however the coils are only moderately cold to the touch.
Performance wise the fridge has mostly worked fine, I would see internal fridge temps of 32 degrees and the freezer would freeze well. It would take at least a full day to chill down once turned on and would rise in temp a bit when stocked with food.
For the last year all of my trips have been at lower elevations. This week I've been on a trip to Tahoe (6500ft) and I've noticed the fridge struggling to stay cold, hovering in the 40s (freezer is still fine). I thought it was because we were just in and out of it a lot but this morning I checked it first thing in the morning and it was reading 40 degrees when it would usually be 32 degree. It was 50 degrees last night and day time temps are in the mid to high 70s.
My question is whether it's possible that the fridge could be low on the ammonia gas just enough that it works okay in lower elevations but at higher elevations it's not working quite as well. I am leaning this direction just because the coils on my fridge are not cold like they were with my other camper.
Any thoughts?
  • There could be many factors that is effecting it:
    1) At altitude it could be cooler at night allowing it to catch up / stay cooler
    2) Could have more wind to cool down the back of the unit at altitude
    3) Parking in the shade at one place and not at the other
    4) Different use pattern (doors open more when down lower)
    5) More or less food
    It could also be that the unit is slowly dying and it is not able to cool as well now as it could before.
    With the fridge in my TCer I was able to see over the years that it was having a harder time cooling till one day I could not get it to cool at all. Replaced the cooling unit and it was good again.
    With the class C I have now (a lot newer of a fridge) I can see how this one outperforms the one in the TCer. On the class C if I plug it in the freezer feels cold in about an hour, on the TCer would take 12 hours on the best day. The fridge is still not that much faster in cooling but it does seems to keep up better once cold.
  • Thanks for the comments so far. I have it running on propane. It seems that my setup is working normally. Maybe we just had it a bit overloaded and it's struggled to catch up. I think I'll look into adding a fan to the back to get some more airflow.
  • stickdog wrote:
    We're at 8,000 ft and the fridge is working fine running on electric. Dometic 2852 set on 2 shady side of the trailer freezer 0-5 fridge 39-42. Days 70-80 nights low 30s to low 40s. Worked as well in AZ but had to set on 3.
    It should you are on 'electric'
    Altitude has no affect.
    Propane....altitude CAN effect flame temp
  • We're at 8,000 ft and the fridge is working fine running on electric. Dometic 2852 set on 2 shady side of the trailer freezer 0-5 fridge 39-42. Days 70-80 nights low 30s to low 40s. Worked as well in AZ but had to set on 3.
  • Cooling unit is SEALED and under high pressure (300# Plus)
    NO..altitude does not affect fridge as in 'low ammonia' etc.
    Low ammonia means LEAK and then there is NO ammonia/hydrogen gas etc
    Altitude does have affect on fridge cooling......thinner air----fuel rich...cooler flame for heating
    What's a person to do?
    Well there isn't a 'high altitude kit', there isn't an 'air shutter' to adjust air ....fridge has fixed air inlet based on propane gas flow/pressure.
    Need to check that burner flame is strong,steady, blue.
    If yellowish/lazy then need to get more air to burner.
    Remove lower vent cover and see if flame improves.
  • Each fridge is different, but commonly the RV sets with dual door do suffer from fridge section staying too warm.
    Never noticed fridge being affected by elevation and I did camp at 10,000'
    I would not worry about it too much after one day checking. Recheck it later and come to the conclusion.
    40F is good temperature for fridge.
