That year(and some other years like my 08) of Duramax have a fuel line problem when under load at high temperature. You can read about it on the Duramax forum.
linkBasically the rubber fuel hoses collapse due to the injectors sucking to hard. One cure is to get heavy duty hoses (the link provided solution) the other is to put a lift pump on the truck to feed fuel instead of having it sucked out of the tank.
The lift pump solution has other advantages for the injectors but is around $1000 pro install vs the better hoses are $100 if you DIY.
BTW: A code reader will likely say you need a new fuel filter or injector rail, or injectors. None of those are the problem it is low fuel pressure that causes the problem. I have a code reader and it kept telling me my fuel filter was clogged. It was not the fuel filter.
One word of caution about the fuel filter. If it was not installed correctly (gaskets pinched) you may be having a air leak and that too will cause the symptoms mentioned.
