Z-Peller
Sep 08, 2019Explorer
Camp woof
My BF 10.4 pre wire solar wiring was behind galley bank of drawers against outside wall behind water pump.Took drawers out and had room to work I mounted solar controller below bank of drawers almost at floor level. Was enough pre wire coiled & marked there to reach controller & cut, then run from controller to battery box. I drilled hole in side of plastic battery box to run wires thru with grommet & siliconed it.
The unmarked #6 wires in your gen/ batt compartments are each one wire pos & neg running between generator and battery compartments. Small wires are from starter switch in galley.
