72cougarxr7
Apr 18, 2015Explorer
I just had an idea! I have some marine primer for aluminum. It is an anti corrosive coating primer. If i wire brush the corroded areas and prime them, I should be able to fill the pin holes with epoxy. The primer should prevent any future corrosion from coming back, and the pinholes are so tiny the epoxy should provide a good repair.
Then I can reframe from the inside, and reseal my corner bead and i should have a good permanent repair.
