72cougarxr7
Apr 18, 2015Explorer
ScottG wrote:72cougarxr7 wrote:
The pin hole is right in the middle of the panel, it is not a staple or nail/screw hole. The back side of the aluminum appears to have corroded through from all the excess moisture. They are 2 small pin holes, but i am concerned the corrosion will keep popping through.
Our last TT had a spot like that. It looked like acid was eating its way through from the back side. It had no leaks in that area.
It never got worse and no other spots ever appeared.
sounds like a similar issue that I have.
I suspect, in my case, it was due to some steel screws or staples that were making contact with the aluminum. With dis-similar metals, and a moisture problem, it is a recipe for corrosion.
