Kyedog wrote:
I am in the market for a new TT. I have gone to RV show and several dealers. I have found a TT that I really like but it is aluminum. My current trailer is fiberglass. I am wondering what the quality difference is between fiberglass vs aluminum. The most obvious is that the aluminum can dent but what else. The pricing on the aluminum trailers are cheaper so logic tells me the quality is inferior to fiberglass. I do not want to make a mistake buying this trailer. I am planing on living in it for half the year and hopefully for the next 10 years. I generally travel 6 to 8 thousand miles a year..
I won't buy a laminated fiberglass skinned trailer. Aluminum sided, stick and tin is all that I feel comfortable buying.
Laminated fiberglass sided campers always seem to delaminate from the glue failing, improper lamination, or from slight leakage. I've seen so many delaminate right on the dealers lot, being new. No way for me.
Plus laminated campers get condensation on the inside of the walls from the aluminum studs conducting the outside cold to the inside. And those aluminum studs are usually hollow (some put wood core into them) and hollow studs don't hold cabinet screws very well without loosening.
I camp at a lot of State Parks and by far, the majority of older campers are stick and tin (aluminum sided with wood framing). Usually only the newer campers are Fiberglass skinned laminated trailers.
BTW, fiberglass trailer are Olivers, Scamps, Casitas, not the Glued together Styrofoam/aluminum stud/Luan laminated campers you reference.
Quality wise, aluminum siding can be repaired very cheaply next to repairing the actual wall of a laminated camper. Also that fiberglass skin chalks badly in the sun and will eventually turn a nasty yellow. Aluminum siding can be painted fairly easy and can be maintained with automotive wax. Also slight leaks may not ruin the walls as they do with the glue in the laminated walls.
