- ScottGNomadI had several corrugated aluminum RV's and would never go back. They damage (dent and rot) easily and leak way sooner than fiberglass. Fiberglass (filon) is EASILY repaired by a competent shop.
If you could find a smooth aluminum trailer like HR once made, that would be good with me but I would prefer FG. - lakeside013104Explorer
troubledwaters wrote:
SidecarFlip wrote:
You don't know what your talking about.
It's not fiberglass per 'se, it's Filon which is a vacuum bonded fiberglass hybrid. It's very difficult to repair if damaged, really the only repair is panel replacement....
Ouch..........Patience Mr Trouble. Everyone is entitled to their own opinion.
Lakeside - valhalla360NavigatorA little correction: Most new RV's regardless of siding use Aluminum studs not wood, so having aluminum siding does not mean you will have wood studs that will rot.
Of course, water inside the walls is a bad thing no matter what construction method is used. - SidecarFlipExplorer III
Bumpyroad wrote:
Acdii wrote:
rbpru wrote:
In my humble opinion, the floor plan and interior components far outweigh the exterior covering.
Good luck
This is the most honest answer here. Both have their advantages and disadvantages, but what it really comes down to, what do you like? You can have a fancy slab side with a useless floor plan, or you could have an ugly rib side with a really nice floor plan, or visaversa.
Way I see it, I don't care what it looks like outside as long as it is comfortable and functional inside.
the construction of the RV is my first "cut". no rubber roof, TPO remotely possible. I want fiberglass sides and roof. then I look for one the size/price/and layout I prefer. I will NOT sacrifice construction for floor plan.
bumpy
I actually prefer a single sheet aluminum roof over anything (but very hard to find today), my last unit had an aluminum roof and it was as good as the day I bought it, 10 years later. My current unit has a textured fiberglass roof. I'd never buy anything with a rubber roof. Way too fragile. - BumpyroadExplorer
Acdii wrote:
Good luck
bumpy - SidecarFlipExplorer III
Care to substantiate your claim? - jorge1958ExplorerI prefer aluminum to. It has a lot more durability then fiberglass.
It's not fiberglass per 'se, it's Filon which is a vacuum bonded fiberglass hybrid. It's very difficult to repair if damaged, really the only repair is panel replacement....- SidecarFlipExplorer IIIIt's not fiberglass per 'se, it's Filon which is a vacuum bonded fiberglass hybrid. It's very difficult to repair if damaged, really the only repair is panel replacement. Filon can delaminate as well.
Aluminum on the other hand don't delaminate and can be repaired more easily plus it's lighter. Builder went to Filon for ease of assembly and cheaper cost. Myself, I'd take aluminum over Filon is I had a choice. - AcdiiExplorer
Good luck
44,050 PostsLatest Activity: Sep 08, 2025
