Dave_Pete's avatar
Dave_Pete
Explorer II
Sep 09, 2014
Aluminum Window Frame Restoration
Has anyone discovered an effective aluminum window frame cleaning method?
I am picturing a shallow, but longer bath for completely submerging the window (aluminum frame, glass, rubber seals, plastic - if any) into some sort of chemical solution that when removed (after a period of time) can be rinsed and the aluminum will be fresh brushed look with NO DAMAGE to glass, rubber, etc.
Has anybody found such a method?
1 Reply
  • aluminum oxidizes real bad , maybe take it apart and wire brush it with a fine wire wheel in a drill. or run this question on google.
