a-d-s
Jul 18, 2013Explorer
APT wrote:
What's wrong with Load Range E tires on youtr half ton? You can run the same pressure as load range C, 35-40psi non-towing and 50-55psi towing. I had no problems with Bridgestone Revo 2 on my 2003 F-150. Liked them far more than the BFG AT load range D I had.
I am going on a lot of advice from this forum on going with LR C vs E. Seems I will get a better ride when not towing, the tires are lighter (better fuel mileage). Plus I will be saving money on an already pricey tire (Tires in Canada are 20% more expensive).
I'm not totally ruling out LR E, but if I can find a good option in C then it seems like the best compromise. Still well whithin the load specs (2470 lbs per tire) whereas the rear axle wr is 4300lbs.
- A
44,066 PostsLatest Activity: May 16, 2026
