shades9323's avatar
shades9323
Am I overloaded?
2014 Ram 1500. Payload 1229 (sad). Gvwr 6900. Gawr 3900 both front and back.
Just truck weight: steer = 3580; drive = 3080; total = 6660
Truck and trailer non distributed: steer = 3360; drive = 3880; trailer = 4060; total = 11300
Truck and trailer distributed: steer = 3520; drive = 3580; trailer = 4160; total = 11260
This was last year so with growing kids and growing bikes I expect an additional 100 lbs or so.
Am I over? Borderline? Time to look for an f150 with payload package? Kick it to 3/4 ton?
  • Old-Biscuit wrote:
    You are over the trucks GVWR with or w/o wdh connected
    7100 with & 7240 w/o
    BUT you are UNDER Axle ratings ---still have 380/F & 320/R
    More about axle tire ratings then MFG GVWR/Payload Numbers
    I was wondering about that. I should be good to go then?
  • Zero issues with those weights or even lump some more bikes and firewood on.
    Happy trails!
  • What are your tires rated for? That is the most important rating in my opinion.
  • Only rating I see that you are exceeding is GVWR. I'm glad to see you have restore almost all front axle weight. How does it tow?
    I towed with a similar half ton at 200-500 pounds over GVWR. As long as the WDH was adjusted well, it was solid at 75mph. I expect the same for you. If you want an excuse to get a new truck, I'd be looking for something with at least 500 more pounds of as equipped payload. That does include some half tons and every 3/4+ ton.
  • You are over the trucks GVWR with or w/o wdh connected
