Fuzzy_Bear
Aug 02, 2013Explorer
First thing you should consider is replacing the rubber valve stems with metal ones. The rubber ones don't hold up well when inflating to 80psi. I had two flats on the rear due to torn valve stems. That in turn led to belt separation. Replaced them with 235x80x17 Hankook ATM but they are too narrow and tend to follow the big rig ruts on the interstates. Next time I will go a bit wider.
Doug
Doug
