I'm trying to determine whether my current solar system is adequate or if I need to add more panels/batteries. Currently I have 2 6 volt lead acid batteries. I have 300 watts of panels 40 amp con...
You need to install a battery monitor. That will tell you how much power you are using. Battery monitor should always be the first device you install long before any other equipment.
