time2roll
Jan 29, 2015Nomad
Plumber101010 wrote:The Hondas only produce what the RV calls for. The extra 400w can still be used for surge performance such as starting the air conditioner compressor. The breaker will not instantly trip with a very short overload same as when you are plugged in.
2) With 2 Honda 2000 watt generators going. And by the math I learned here, 30 amps x 120 or 115 or 110 (still confused about which it is, it seems to vary in google) is 3600 watts, does the extra 400 watts go anywhere in helping me to run the plug in heaters, or no because the breakers and wring are still going to pop regardless of how much juice I have coming in over 3600 watts / 30 amps? If 30 amps is 3600 watts and I have 4000 watts, is the extra watts lost?
