time2roll
Jan 29, 2015Nomad
Plumber101010 wrote:Yes you can still use the regular outlets on the generator. The cord needs to be #12 wire if powering an electric heater.
3) Regarding tripping breakers when running couple heater fans, Assuming at LEAST I can plug an extension cord into one of the Hondas 120 outlet in addition to the 30 amp plug and get it that way?
But you are far better to run the furnace and use propane.
You can use the convenience outlets in the RV. But just like at home... if you put two heaters on one breaker it will trip.
