larry_cad
Jan 29, 2015Explorer II
Watts and horsepower are similar. You can drive a car with a 400 hp motor and if you drive slowly, the motor puts out only 100 hp. Same with your generator. If the load you plug into the generator requires less than the max rating of the generator, the generator will not produce the watts. Oh, and you will accordingly use less gasoline. The watts won't be wasted because they will not be made........from the gasoline.
