SuaveGato
Sep 13, 2014Explorer
AnEv942 wrote:
I guess my question is was the work done 2 years ago that the business for the TS is closed, original owner deceased that worked on unit, but whoever did the work should have some input?
I had read into your other current post you had recently acquired camper-my mistake. I doubled checked post dates- as Im am a bit puzzled though, this and other current thread dont quite jive.
Hello and thank you for the reply. I'm unclear on what your question above is? What is TS? The basic time line of events is as follows. Approx. 2 years I bought this TC knowing at the time of purchase that the generator "would run but shut down when the breaker was thrown into the ON position" that's when I posted some of my previous posts, hard starting and trying to figure out what was causing the shut down issue. Then, once I tore it apart and found all of the melted wires etc. I stopped, it was clearly a BIG problem and over my head. I am a small biz owner, so I got tied up with work etc. and did nothing about the issue until December of 2013 when I got some time and money and took it into RV Doctor George here in Sacramento to have it diagnosed and fixed, or so I thought. there's a whole "back story" about that I can explain if anyone cares to hear but irrelevant to this issue. He had it for 2 months, I got it back after the new wires and new brain and it still does the exact same thing it was doing that I took it into them to fix, approx. $2,000 later. I notified George over the phone, he said he was "tapped out" on ideas and had too many hours into it, that I should take it to a generator place? I got busy with work again, then approx. a month ago, I decided to get back to fixing it and called to talk to George and express my displeasure etc., see if he was willing to do anything etc. and that's when I found out he had passed. So here I am. Still just using the 12v or shore power when I camp. Hopefully that sheds light on the time frames? If not, I'm happy to answer any questions, I'm just unclear what you were asking and don't know what TS is?
The 'brain A6060 control board controls everything- it is quite expensive. To replace more than likly you will need to drop generator. Not that difficult but some work. I assume, though your older pics looks like youve had open and more room than I have, I doubt room enough to actually remove tins for access to board.
Behind the heat sink in the rectangular box next to fan is the board. if you dont have, download manuals
http://www.generator-parts.com/manuals/generac-rv/0D1752.pdf, repair/diagnostic manual, lists the shutdown features and a troubleshoot guide
http://www.generator-parts.com/manuals/generac-rv/0A9195.pdf
diagrams and parts list...
Thanks for the info. I doubt I'll drop the whole thing just to see if my board is still good, maybe I'll see if there is a place that could bench test it? If it's good, I'll ebay it or something? I'll also go D/L the manual, thanks for the link!
44,061 PostsLatest Activity: Apr 08, 2026
