MN Ben wrote:
As you were adjusting, were you at a level load (no sag) all the time. Actually I think you mentioned you have no sag unless you have the horses hitched.
Had to drive over to a big flat level parking lot to actually see how the rig sat, my driveway is sloped and the street has a high crown. I knew it had way too much pressure from the get go. From that point on I slowly played with reducing the pressure, driving about then back to the same parking lot until I was almost back to level from the inital tail high when I reloaded the Lance after the install.
Mostly I was just playing with the system and getting the feel for what different pressures would ride like. I was hoping the best feel would with the upper and lower stable loads engaged and the bags just there for when I am towing and it is.
