otrfun's avatar
otrfun
Explorer II
Feb 18, 2016
Another 1/2-Ton Bites the Dust :)
We finally decided a good payload margin was more important than the smoother ride (of the Ram 2500), so . . . we pulled the trigger on a new 2016 Ram 3500 Cummins CC SB 4x4 . . . having trouble getting this smile off our faces! Yes, the Tundra 5.7 we traded-in accelerated quicker. However, I'm finding the Cummin's methodical, low drama approach to acceleration addictive, and strangely relaxing :)
Ended up purchasing this truck in CA (we live in AZ). Very tough to find Tradesman Ram 3500's (with the Chrome and Popular Equipment packages) that also have the trailer brake controller, rear camera, and 5th wheel/gooseneck options. My research showed about 3 of 'em west of the Mississippi (in white or silver). There are literally hundreds of 'em configured like this without the 5th wheel/gooseneck option. Don't understand why--especially on a high payload truck like the Ram 3500. For us, the 5th wheel/gooseneck option was a no-brainer for $400. It includes a 2nd 7 pin connector in the bed (in additon to the 7-pin connector on the bumper). I like the fact it keeps the bed flat when a hitch is not in use. Plus, being OEM, it's designed as an intregal part of the frame--IMO much more seamless than the aftermarket solutions I've seen.
Anywhoser, it was a 430+ mile (all freeway/interstate) drive from the dealership, home. Dealer topped off the tank before we left. Stayed with the flow of traffic in CA (75 MPH) and in AZ (80 MPH). The route included about 50 miles of CA rush hour traffic along with a number of 4000 ft. passes. Reset the EVIC before we departed. EVIC showed an 18.5 MPG average at the end of the trip. Hand calculated at 17.5 MPG. Only got 16 MPG in the Tundra 5.7 driving the same route/speed earlier in the day.
Thanks to Greene728 for his suggestion to lower the air pressure on the 3500 to soften the ride. Lowered the front to 70 and the rear to 60 after our trip back. Noticeable difference in the ride. FWIW, noticed there was very little road contact on the outside edges of the tires with the tires at 80 lbs. (tire "nubs" still visible). It's possible the lower pressure may actually improve tire wear when empty.
Want to thank everybody for their help deciding whether we should go with the Ram 2500 or 3500. For our immediate plans the Ram 2500's payload would have probably sufficed. However, went with the 3500 since there's very little difference in price. We wanted to error on the side of caution in terms of payload . . . one never knows what you may want to pull in the future. It's mind-boggling this 3500 has almost *triple* the payload of the Tundra!
Tried to post some pics, but the Photobucket links won't work :(
  • Otrfun
    Glad you looked at and checked your tire pressures as they do in fact make a tremendous difference. And with the weight your currently towing you'd probably be fine leaving them at or around the 65psi mark year around. As another member above stated, I only inflate to 70-72 psi during towing season with + - 2000 lbs pin and hitch weight.
    Your gonna love that Cummins more and more everyday!
    Congrats!
  • minnow wrote:
    O.P.; Is your's single rear or double rear tires ?
    Minnow,
    In his other thread I believe he said he was looking at SRW only. So I'm betting that's what it is as he was comparing it to the 2500 in regards to payload capacity.
  • O.P.; Is your's single rear or double rear tires ?
  • Ventureman wrote:
    Congrats and enjoy!!
    What gears do you have in it?
    3.42 is in all SRW Cummins trucks.
  • We love ours also
    congrats.
    with the Tradesman, we did not get the floor setup in backseat. so we made ours. so great when traveling to make a flat floor. amazing how much room is back there
  • rhagfo's avatar
    rhagfo
    Explorer III
    Congratulations on a nice new TV, No the Cummins with not be first off the line, but will move one Heck of a load.
    You might want to look at the Tire capacity on the side wall, and scale the empty weight of your rear axle and drop the rear tires closer to 50 to 45psi, I only air to 65, when towing with a 2,200# pin weight.
  • Congrats, you'll love that thing. I've never owned a vehicle that impresses me as much as my 2015. It's amazing how comfortable these things are as daily drivers and family haulers when you consider how well they perform with a fifth wheel or trailer in tow.
