Golden_HVAC
Apr 30, 2013Explorer
Hi,
200 watts should work well in your situation.
If you have a laptop that will play the DVD, it will only use about 20 watts, much less than a typical TV set, if you want to go that option.
You would also need a 150 - 300 watt inverter to run the TV set or laptop, and I would recommend just hooking up a new cigarette lighter outlet someplace with #10 wire and a 20 amp fuse. Run both a +12 volt and ground wire in copper to the plug, just tying to the frame will not provide as good of ground and will cause greater voltage loss.
SunElec.com is one place that has difficult to beat solar prices.
I would recommend a 12 volt (nominal 12 volts is actually about 21 volts open circuit (with no load on it)) solar panel, and a PWM controller, it is much lower cost. Pulse Width Modulation. MPPT is more energy efficient, however with the low cost of solar panels today, PWM works out less expensive overall, because the controller cost is about 1/2 the price.
I would recommend 100 to 175 watt solar panels, unless you really find a great deal on the larger panel, and it will fit in a good area in your roof. Many who select a larger panel regret it due to the difficulty in locating a large enough space to mount it. My 120 watt panels where also difficult to locate too, the 75 watt and pair of 45 watt where an easy fit.
Back in 94, the cost of a pair of 45 watt panels where over $500. Now days spending more than $2 a rated watt is no good deal at all!
Installing the system is really easy, you just hook up the +12 to the right locations, and ground -12 in the other side. From the panel, you hook up the + and - to the controller, and then + and - to the batteries.
For panel mounts, I cut 2" angle aluminum from Home Depot to 6" long with 3- 3/16" holes for #10 screws into the roof, and 5/16" hole for a 1/4-20 bolt into the solar panel. Lots of rubber roof sealant prevents any leaks, and also helps hold the panel mount in place.
Your refrigerator, CO meter and propane leak detector together use about 35 amp hours per day, about what the single 120 watt panel can provide. The next panel will run all the lights, pump, and other loads like the radio and TV.
Water pump load is really insignificant. In a 2 week trip, it can pump 2 gallons per minute, pumping 120 gallons while using less than 8 amp hours.
Good luck,
Fred.
Good luck,
Fred.
44,059 PostsLatest Activity: Mar 18, 2026
