Community Alumni
Oct 05, 2016Not applicable
The bars can flex a whole bunch more than that. I typically run more flex than that. They're not rigid and designed to flex quite a bit. According to Blue Ox, you can use as many links as you need and it will not damage the bars. If you need to transfer more weight, use more links.
Get across a CAT scale to find out if you're actually carrying too much weight back there or if it's just suspension sag, which seems to be a common complaint with the 250's. If it's just the suspension then some suspension aids like rubber springs or air bags can easily correct the level.
