Lynnmor
Oct 06, 2016Explorer II
Hannibal wrote:
Are the springs softer or are the blocks shorter to make the newer trucks sit level when empty? I see the same GVWR's offered on Ford's website. My 2010 sits about 2" high in the rear unloaded.
They returned to the higher blocks in the later models. You are comparing apples and oranges, as the suspension is different in the older models. The main springs are more flexible unloaded for a better ride, when loaded down to the heavy over load springs they will, in theory, carry the rated load.
