Community Alumni
Oct 11, 2016Not applicable
Mike Up wrote:
What I'm saying is that if he can't get the F250 level with the "1500 lbs" WDH spring bars, then he surely was overloading his F150 Hitch as the F250 hitch is rated at 1400 lbs tongue weight and the F150 hitch weight is rated at only "1050 lbs."
He should not be using anything more than 1000 lbs spring bars on the F150 as it's max hitch weight is 1050 lbs., not 1500 lbs as the bars that were used.
I use to own a 2010 F150 as well.
BTW, F250 w/Diesel hitch rating is 1,400 lbs with 2.5" hitch or F250 w/6.2L Gas hitch rating is 1,250 lbs with 2" hitch.
Just about bought a '16 F250 right before I bought my '16 F150. I needed better mileage than the F250 since I commute with my truck and still have great payload and tow capacity on the F150.
I see what you're saying. My mistake. I was thinking of the Class V hitch for the Super Duty.
