Need-A-Vacation wrote:
Gates59,
What tires are on your truck? What psi do you run in the tv tires when towing? There is a chance (probably sway you feel, but..) if they are the stock p rated tires, it could be them. Is it kind of like a "wiggle" you feel, almost like a kid who can't stand still when they need to use the restroom? Lol
If you go the side friction bar route, I have heard (never used one) that you need to remove it to back up.
Good luck!,
Chris
I have the original 17 inch tires. They are properly inflated to spec and so are the tt tires. It is kind of a wiggle but not all the time. If I keep it under 60 mph I'm all good.
