ib516
Sep 25, 2013Explorer II
Engineer9860 wrote:
Other than the Ford SuperDuty front suspension it looks like the same old truck.
It may look the same, but clearly, you missed a lot in the article....
Besides the front suspension changes, it also has the strongest frame in the industry (50,000 psi), game changer coil spring rear suspension (2500) and/or air suspension, 3 stage/setting exhaust brake in the diesel, highest 2500 series tow ratings gas and diesel (2500 RAM ratings are the same as the other guys 3500 ratings), most hp and tq in class in the gas engine, most tq with the diesel engine, most hp in the gas engines, only gas engine with variable displacement in a HD truck....etc.
44,071 PostsLatest Activity: Aug 30, 2026
