Grit_dog
Jan 09, 2021Trailblazer
jdc1 wrote:ksss wrote:
Typical of a lifted suspension. Man that trailer must be 43ishfeet long.
Exactly. The springs on lift kits are soft. His tires probably aren't rated for that weight either.
Highly unlikely that those were lift springs in the back, for the same reason you mentioned. Truck probably level after the lift. IE 6” up front 4” rear lift blocks. So it makes the “sag” look worse than it is. And the tires are likely rated higher than OE tires.
Agree too much trailer for a brodozer, but probably not as bad as it looks. However it’s not as fun to just say “nice truck” and move along.
