majorgator's avatar
majorgator
Another Generator Option
I stumbled across this line of generators this morning and it looks like they pretty much meet every requirement of the RV world. In some cases, it appears they even exceed the benefits of the other major manufacturers. I'm not endorsing them, but just felt I'd pass it along.
Boliy Generators
    Boliy Generators
    Search generators (including that one) on the *Tech Issues* forum.
    For some brands, try the (Tech Issues) archives also.
  • For the same money and a little shopping you can get a Champion inverter type genny with a warranty, a decent reputation and parts and service availability...
    What's not to like?
    B.O.
  • Huntindog wrote:
    Major, I noticed that you are pretty new here.
    I want to give you a belated welcome to the forum.
    Generators are one of the most discussed items here.
    So unless it is a brand new product coming on the market, it has been discussed here, and almost always with some first hand testimony.
    Great generators are thought by most to be the Honda and Yamaha invertor types. The Champion is making a pretty good case for making it a threesome.
    Good ones are what I call the tweeners. Not nearly as loud as the contractor ones from the big box stores, or as quiet as the great ones.
    They come with some nice touches for RV use and are really affordable in initial price. The Champion 3500 pull start and remote electric start are the most well known of these.
    Then there is the rest, rounding out the bottom. Some may be a little better than the others, but as a class, they aren't considered a good fit for RV use by most.
    The Boiley falls into this catagorey.
    Thank you for the comments. Yes, I have read several threads about generators in my short amount of time trolling this forum. I especially enjoyed the back and forth mud slinging about the cheap Harbor Freight generator (LOL). If there's any one thing I've picked up in reading about them is that mostly everything comes down to a matter of economics. Personally, I could afford a yammy or a honda, but many people simply cannot. For those people, there's no convincing them to shell out the cash for the blue or red. I'm cool with that.
    I stumbled across this product line after seeing an ad for a used one on CL. I think they were asking $600 for it, which led me to investigate further. As I said, no endorsement from me, but quite frankly, if someone pulled up next to me in their TT and whipped out a generator, I'd rather it be this one (with the low DB noise level) instead of a typical cheaper and louder unit ;)
    After doing a bit of research into foreign manufacturing and importing a few years back, I learned that for many products, differences are very subtle. Not that I'm suggesting the Boliy is an equivalient to a Yamaha or Honda, but marketing and ad campaigns play a big role in pricing, popularity, and acceptance. I don't buy power tools from HF and I don't buy rods and reels from Wal-Mart, but if I were in the market for a generator, I'd be willing to shell out $500 to $600 for the used Boily based upon what I've learned.
  • Major, I noticed that you are pretty new here.
  • I have one... Runs great below 8000ft... Does not like any altitude... Even with a jet mod.... I use it now as a backup home genny... I run it once a month for about an hour... I like that I can run the carb dry...
    I've since been shopping hard... Gonna look at the champion or two yammys...
  • Just me, but if I was to buy a low cost generator it would be a Champion 3100.
  • The biggest reason I would not buy one is parts. Everything breaks, getting parts for this one would be a nightmare.
    They are not cheap enough to be disposable.
    As for the "up to 22%", recall it says "up to", which means it could also be "less then" under most conditions
  • Hi,
    I tried one. I finally sold it at a garage sale for $100.00. The warranty and exchange policy are a bad joke. The hardware (screws etc) rusted within days. The battery is soldered in place, so changing it would be a night mare.
  • From the link
    BOLIY Pro3600SI (model number matches engine kw output not ac output) is a true Digital Signal Processing
    (DSP) inverter generator. Similar models including Honda, Yamaha, Robin Subaru, & Kipor use transistor
    induced technology which is just simulated signal processing. With the advanced German made
    microprocessor, the DSP processor results in a power conversion rate of up to 22% higher than comparable
    inverter generators from Honda, Yamaha, Kipor & Robin. The voltage is adjusted to maintain at stable 120V by
    the computer inverter module. The light weight design makes them ideal for transportation without the need
    for cumbersome wheel kits and extending handles
    I'd be interested to hear opinions about the 22% higher efficiency ...
