hohenwald48
Nov 15, 2015Explorer
jmtandem wrote:I just thought it seemed reasonable that the tongue weight should be distributed between the front and rear axle at the same ratio as the empty TV weight.
Maybe Nissan is different. However, I don't think you will find your statement supported by any tow vehicle manufacturer.
You're probably right. I just thought it seemed logical.
If you adjust your WDH based on the fender to ground measurement method isn't that what you're doing by adjusting the bars to lower the front and rear of the TV by an equal amount?
Hitched I have #2920 front axle and #4040 rear axle. Unhitched I have #2980 front axle and #3020 rear axle. Weights vary a little based on gas tank and "junk in the trunk". I have a little over 6,000 miles over the past couple of months with this set up.
I may be over thinking the whole thing.
44,066 PostsLatest Activity: May 18, 2026
