opnspaces
Jul 01, 2019Navigator III
If the switch never lights up it sounds like a blown fuse or a bad switch.
With the switch off you should have 12 volts on one side of the switch to ground. If the switch is on you should get the same voltage on both sides of the switch to ground.
44,066 PostsLatest Activity: Apr 15, 2026
