stngls wrote:
Sticker on door--- GVWR 5550#, GAWR 2950#, GAWR RR 3200#.
You also need to post the payload capacity from the driver's door yellow sticker. Read Greene728's post.
And you need to determine other specs:
Does the car have the factory tow package?
This includes type III/IV receiver, wiring for brake controller, trans cooler, 7-pin connector and towing rear end ratio.
Your dealer should be able to provide this info from the car's VIN.
As was said, towing a boat or Uhaul trailer are not the same as pulling a TT.
The air resistance of that big barn door thru the air is way different and takes some education, a lot which is technical.
