stngls wrote:
busterbrown73 wrote:
I owned the Envoy's little brother, the Buick Rainier with the I6 powerplant. If your Envoy has airbags and can be equipped with an auxiliary transmission cooler, decent brake controller, and quality WDH,
Way over my head here. It has air bags and that's all I know. Guess I have to go to GMC dealer to find this out.
You'll need to understand the dynamics of towing before you hitch up. Weight distribution hitches are almost always required with any travel trailer that are bigger than tear drops and micro's. Keeps the load on the TV (tow vehicle) spread out over both axles. Your air bags do a good job alone but the WDH will force weight on the front end for drivdability.
Secondly, any trailer weighing in at 3,000 lbs or more with it's load (know as Gross vehicle weight ratio, GVWR) need to have a trailer brakes. This requires the use of an electronic brake controller on the tow vehicle. Remember, arresting your truck and camper from highway speeds need to be done by all axles, both camper and truck. The controller orchestrates this.
Thirdly, towing takes a toll on your transmission. Component of early tranmission demise: HEAT. Towing creates heat. Your truck platform incorporates part of the radiator as a in-line transmission cooler. Even though it works for regular everyday driving, towing adds much more stress (and heat) to the tranny. Adding an external transmission fluid cooler in front of the radiator will keep your trans temps in the favorable range. I wouldn't bother with a stealership visit. Any reputable independent transmission or repair shop/mechanic would be able to install one for you. It took me about 1 hour to install one on my Buick.
IMHO, if you're unsure of what any of the forementioned components are, I'd spend more time learning about the fundamentals of towing and ask as many questions on these forums as you possible can. Don't be discouraged by the "need a full-ton diesel to pull a pop-up" police that will comment on your equipment. Just remember, what ever you tow, keep it safe and within the limits of your rig.
