- RobertRyanExplorer
69Avion wrote:
The spindle assembly is attached to the rear of the trailing arm. Some companies in the US are using air bags instead of the coil springs.
Air bags are another common alternative. You have about 6-8 different suspension systems overall and about the same number of hitches. - cpaharley2008ExplorerI'm moving to Austrailia....
- 69_AvionExplorerThey aren't torsion arms, since they have no torsion bars to go with them. They appear to be a simple trailing arm with a coil spring and a shock absorber. The spindle assembly is attached to the rear of the trailing arm. Some companies in the US are using air bags instead of the coil springs. Either way, it appears to have decent travel.
- profdant139Explorer IIOh my heavens, check out that suspension!! I don't even know what those wishbone leaf spring torsion arms are, but I want some.
- GENECOPExplorer IIAustralia has all the nice off road Trailers.....we in the USA need to get it going on....
44,048 PostsLatest Activity: Aug 21, 2025
