Kayteg1 wrote:
I also weight the truck and I have 9250 lb on 9900 lb rated rear axle.
If I understand correctly, the 9900 lb is from the door sticker/decal. If so, I would be comfortable with that.
It does make me question the 9250 on the rear axle. If the TC is 5600 lb, that means the rear axle load is 4300 without the TC. Am I missing something or is that correct?
Kayteg1 wrote:
Driving via the scales show that my camper has center of gravity behind the axle as it took off +- 100lb from front axle.
I don't think the COG is behind the axle. I think it is directly over the axle.
On my extended cab 2500, my TC added about 200 lbs to the front axle. On my Quad Cab, it lightened the load. I do not recall the amount, but it had to be more than 200 lb. I think the front end weight change is due to wheelbase, not the location of the axle in this case. On my two trucks, the TC location relative to the rear axle is the same.
I moved the TC back one inch on the Quad Cab, and it only reduced the front axle load by less than twenty pounds.
Wayne
