Reisender
Jan 18, 2020Nomad
NJRVer wrote:
Other thing to consider.
I did a job for a customer with a tesla and he told me he rarely, rarely ever uses his brake pedal.
He said the gas pedal works if push it you go, and if you let off of it the car will stop.
He said it took getting used to at first but now he barely needs the brake pedal.
Could be instance in OP's link where the driver was doing that and in a panic situation stomped on the gas pedal instead of the brake because they were so used to never using the brake.
That is exactly how “epedal” works in a leaf and “hold” works on a Tesla. You can literally go weeks at a time without touching your brake pedal. Which is why EV’s generally never need brake service.
44,071 PostsLatest Activity: Aug 16, 2026
