ttugurl's avatar
ttugurl
Another Towing Question
We just purchased a Puma 28BHSS, which has GVWR 9063 lb. Unloaded Weight 7513 lb.
Our vehicle only towed 9100lbs so we traded and purchased a newer F150 with their newer towing capacities:
3.5L V6 CYLINDER ENGINE
Upgraded Front Stabilizer Bar
Dead Weight Hitch - Max Tongue Wt. (lbs): 500
Dead Weight Hitch - Max Trailer Wt. (lbs): 5000
Maximum Trailering Capacity (lbs): 7000
Wt Distributing Hitch - Max Tongue Wt. (lbs): 700
Wt Distributing Hitch - Max Trailer Wt. (lbs): 7000
3.5L EcoBoost V6 375 @ 5,000 470 lb.-ft. @ 3,500 13,200 3,230
We know F250 would have been a better choice, but it would have been too much truck when we aren't using.
We are new towers. Should we be worried or are we safe? Our RV came with a free hitch but we upgraded for the better sway bar/hitch.
  • If I am reading your post correctly, your Max. towing weight is 7,000 and your trailer is 7513..unloaded?
    I tow right at 5,000 with a 1500 and it is doable. At 9,000 #'s, I definitely would want a 250 or 2500. Just my opinion.
  • No Mountains! Short 3hr trips to Texas Coast a handful of times a year with longer stays during summer.
    I don't understand the numbers. In my mind 13200>7400 by a huge margin.
  • Ask yourself some questions to answer your question:
    1. What parts of the country are you doing most of your Rving in i.e. mountains with steep grades or mostly flat areas. Do you have an exhaust brake system for mountain grades?
    2. how often do you RV? week ends, once a month, do you stay out for weeks or months at a time?
  • Just looking at YOUR numbers, you have answered your own question!
    You will be over the max trailer wt, the max tongue wt.
    A 250 would be needed for that trailer, for best towing, and to stay within ratings. Will your new 150 work?? Maybe, but not safely, being that far over ratings.
    Jerry
