Limoges_Camper
Sep 07, 2014Explorer
westend wrote:
Wow, if you can do the work as nice as that drawing, it should turn out great, good sketch.
I know they do make adhesives that bond dissimilar surfaces to foam. Can't recommend one as I've only used ones that come in tubes for panel bonding.
I'm going to use a water based contact cement. I don't care about 200% contact with three foam: by adding 1/2" plywood to the 1/4" plywood, I no looney med all the structural properties of the foam panel.
Thanks! I did it in AutoCAD. Just a bunch of rectangles. :)
