Hi, I am new to rv's so this might sound dumb to . I was trying to raise my antenna , and it would not go up , I noticed that the spring just above crank is missing, could this be the problem? Look...
Is yourRV new? It's possible that the Dicor was laid down then they lowered the antenna on the wet Dicor! Out 05 Cherokee had a sticky spot when trying to raise it. Turns out the problem I had is what I just mentioned.
