I made this so I can use this to keep the hitch from bouncing around when towing, I have a Chevy with the sloppy hitch that they're known for so my hope is that when I have to weight distribution bars (600 pounders) connected that the hitch will not slop around so to speak, I think it should be plenty strong because the aluminum pieces are almost three fourths of an inch thick and then by using 5/8 (or 9\16 they were they next size up from 1\2 inch ) grade 5 bolts they have a tensile strength of i think over 18,000 pounds so I can't see them stretching and I also went with grade 5 washers so everything's matched correctly I can't see the aluminum giving way because it's so close together but I will know after the first trip if it worked, if the aluminum does not work I will have to go to steel my problem is though I only have a half inch drill and the aluminum plates I used are three quarter inch were already drilled I just needed to widen the holes in a bit.
That hitch vice looks good, I wonder if it can be used vertical not horizontal like it shows in the video.
