GeoBoy
Sep 06, 2019Explorer
Turtle n Peeps wrote:
You have no worries about having lube on your bolts.
Bolts don't loosen up because they are lubed up. They loosen up because they are not properly tightened.
Think of rod bolts in an engine. They are in lube all the time 24 hours a day and they don't loosen up or have loctite on them. They don't loosen up because they are torqued properly.
X2. Use anti-seize on the caliper bolts and torque to manufacture spec. I was a Saab mechanic and never had a brake caliper fall off a car ever.
44,071 PostsLatest Activity: Aug 23, 2026
