mrgrim007ExplorerSep 05, 2019Anti-seize on brake caliper bracket?I just got done rebuilding the front-end on my 2002 Suburban (ball joints, pitman arm, etc.). The bolts that hold the brake caliper bracket to the knuckle always seem difficult to remove. This tim...Show More
Cummins12V98Explorer IIISep 06, 2019Slide bolt threads should have medium loctite, and YES properly torqued. DRV had a recall on the subject.
Related ContentSuburban Anode Replacement - Anti Seize?Stuck Caliper PistonP32 sticking rear caliperAir Brake Calipers....YIKES !!! (UPDATE)Brake Calipers
