1handyhubby's avatar
1handyhubby
Anti sway bar question
I have a lot of movement with this heavy camper so I'm looking to replace the stock anti sway bar with a Road Master. Anyone out there know if they come with the end links or did you use the OE ones? And, anyone have an F350 that has installed one? I crawled under neath and it looks like I would have to have it on a lift to replace it. The camper is on and I was hoping to change it in the driveway. Thanks
  • I installed the Big Wig anti sway bar and everything came in the package. Never had to remove the camper off the truck. If need be just take some of the weight off the suspension by lowering the camper jacks make sure to loosen the tie downs first.
